Ga door naar hoofdinhoud
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Is dit een goede vraag?
6 opmerkingen
Do you have a working desktop PC? So you could test the disk.
door
i have but im not sure if it has internal hdd
door
How did it break? did you drop it? spill something on it?
door
i installed updates and the system crashed
door
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
does it have hdd though?
door
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
door
Voeg je antwoord toe
Tomasz Kowalski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 475
