My TV keeps switching off and on again when first started
My TV keeps switching off and on again when first started. Can I rectify this without the need to take to an engineer.
Is dit een goede vraag?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 694
I've just started to experience this with my UN55KS8000F; I also believe it's related to the power board, due to the consistent power-cycling. I'll add that just before the TV developed this issue, the image on the screen faded to a greenish tint before powering-down. All user-level troubleshooting thus far has not solved the problem.
Troubleshooting performed so far:
1) unplugging TV, letting set for a few minutes, plugging back in
2) unplugging TV, holding power button for 10+ seconds, letting set for a few minutes, plugging back in
3) during power cycling, holding power button for 10+ seconds, letting set, plugging back in
4) disconnecting the HDMI on the mini one-connect, and repeating troubleshoot #1
5) disconnecting the mini one-connect completely, and repeating troubleshoot #1
Nothing has worked thus far and the issue remains entirely.
I’m going to get my DDM to start testing inside the unit, as well as look for any damaged components. I’ll let you know what I find.
door Robert
Any joy as yet? My TV UE55NU7172U has just started doing this.
door dankirven
@dankirven ... does this happen when switched on by remote or onboard buttons or both?
door jostewcrew
@jostewcrew both buddy
door dankirven
@dankirven ... if you can remove the back cover and gain access to your boards.....youll see a ribbon cable coming from the main board to the ir sensor to the tv's bezel. disconnect this. also, youll see another ribbon cable that leads to the onboard control buttons. disconnect this as well. with both of these disconnected, try to see if the tv will remain on. this will rule out if it is these two boards before moving on. if you find that this solves the issue, replace one connection back at a time to see when ot starts to malfunction again. this will be the issue when it does. if it still happens with both disconnected, reply back for further instructions.
door jostewcrew
1 commentaar meer tonen
