Ga door naar hoofdinhoud
A 5-inch Android smartphone, powered by MediaTek MT6592M paired with 1 GB RAM. Not to be confused with the Doogee Valencia2 Y100 Pro.
6 Vragen Bekijk alle
Doogee S60 not charging
Please who can help.
My Doogee S60 is no more charging. I need help to have it powered on.
I am in Canada, Ontario. Please who do I contact?
I will appreciate a swift answer.
Thank you.
Is dit een goede vraag?
Score 4
11 opmerkingen
My S60 is about 3 Months old Not only do I have a charging problem but also a phone heating up problem. Even at idle my phone battery gets hot then with little 2min use the phone shuts of and sometimes won't turn back on for a while. It even does this when I boot the phone in safe mode.. I can't believe how slow doogee replies, 3 weeks just to get one reply and I'm not any close to them fixing the problem. What a useless company
door
I have the same issue with my S60. The only way to recharge it (reliably) is to turn off the phone and use cordless charger (Qi charger). But DO NOT recharge it overnight while you sleep, the phone gets REALLY hot at times. Better keep an eye on it.
I’m in Ontario Canada too, there’s no service center here. We are on our own. That’s why the phone is priced at that level. We paid a faction of the real S60 by Caterpillar. And I’ll NEVER buy another DooGee phone again….!
door
Oddly enough mine is charging again via cable and wirelessly. What did I do? Threatened it with being replaced by a new phone!! Crazy yeah, but it's fine now. One other thing I did, installed an app called 'accubattery' and that kind of helped resolve the problem by making sure i don't over charge the phone. Worth a try.
door
I have the same doogee problem..the company has closed down the I offices in the middle East.
door
Regarding s60 lite ( doogee) I have a strange problem!!!
I forget my pin code then I whipped and reset my phone, now I can not open my messaging application.
Is there any one who can help me?????
door
6 commentaren meer tonen
Voeg een opmerking toe
13 Antwoorden
Het nuttigste antwoord
I have had my S60 for over a year now and it is best phone i’ve had. Charges perfectly wirelessly or via cable. Definitely a great phone. You got issues then contact doogee, they are slow but will respond.
Hasta la vista baby!!!
Update (02/04/2019)
If you have a wireless charger try that. Mine stopped charging with cable so i used wireless for about 6 charges. After that i charged it via cable and adapter in my car, this worked and now i charge in house with normal cable and charger.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Less than 2 months later and mine won't charge wirelessly or by cable. Someone at Doogee please read this and help? I don't want to give up this phone.
door
Same problems here...my Doogee S60 lite can't charge via cable... bought 3!!! wireless chargers to power it up...worked with the 2 of them but after one two months no more wireless charging...i went back to cables...i tried many many of them...only one can charge it very very slowly...(off phone, after 11 hours or more can get to 100% ...tried that also with different adaptors...same thing)... phone was bought may2018... problems started about Christmas same year...
door
Also ui not responding many times, fingerprint not reliable at all and notification led light not working or working for someone who has owl's or hawk's eye to see it...
door
If you have trouble charging your s60 lite/s60 or it ceases to charge via micro USB cord, you must replace the usb board (firstly you have to open the phone, precision soldering is required, several different precision screwdrivers, or one with different bits including tiny torx bits, and a very good pair of needle nose pliers) I did the repair on my own after watching the one youtube video I found, and I changed the battery as well but the new charging board only lasted about 6 months. Otherwise, depending on where you get a board its about $16US without shipping costs. Also, if you're going to keep the phone for a while, I suggest getting a spare because the usb board replacements tend to expire rather quickly. I've not had any luck charging wirelessly to date. Good thing this isn't my only phone because every 6 months or so this seems to happen. Doogee customer service is trash in my opinion as well as the phone and I consider it to be a high cost paper weight being that it fails so frequently after new parts are installed, I definitely wasted my money trying to find a rugged phone to keep up with the aviation industry and that's to say the least.
Score 2
1 Opmerking:
mine is not turning on and not charging, but the cable and battery is fine
door
It may be the charging circuit, I got a similar problem on my y100 plus and the technician said it was because of a problem in the circuit but I don't have any details about it.
Score 1
Hi kadiriibrahimd,
If your smartphone is not charging properly anymore is due to the fact that the battery is thouroughly exausted of being charged whole the time. If you keep your smartphone charging while the battery is already fully charged it will have a negative influence on the battery life. This is usually the cause of a faulty battery. I suggest you buy another battery (2 or 3 ) and advisable would be a charge capacity of 4000 mAh.
Hope this might help
1 Opmerking:
The majority of charging problems with S60 are related to the USB connector. Don't buy a replacement battery before you are 100% sure that connector and loader board are fine.
door
My honest opinion ....
Never buy any Doogee phones, after a while it does have flat charging problem, not from charger but from the phone.
If leave for days, it may automatically starts charging back.
I have shoot 1, and my wife also owned shoot 1, after a year the two phone started developing same issue.
Good side of doogee phones are actually numerous but this dead automatically anomaly can never be over emphasized.
I have the same problem. My Dogee S60 is not charging sometimes. After i push it in a angle it charges.
Still it takes a whole night to charge for 30%.
Also Bleutooth and Wifi stops working after i push it on (about 30 sec it stops the services)
I just have it for 2 months :(
Kg,
Coco
3 opmerkingen:
My Doogee S60 mobile is damage by fall in water, Please tell me where is repair it. From India
door
Hello rosenboom,
Pretty sure that's the usb connector. It gets worse and worse. The trick with angle will not work forever. You can try other USB calbles maybe you find one that works for 1 month more.
But eventually you will have to replace the loader board.
Chilli
door
Got same problems with my s60...i solved it temperately by using a wireless charging dock, till one day wireless charging stopped too...i bought 2 other wireless chargers to be sure, same no charging problem...i bought a new charging port(female) to change the old one inside the phone, i also put a permanent magnetic plug (i cut with razor a small piece of the usb cover -im not 100%sure that now is waterproof-so the cover can be pushed back , so i wont destroy the usb port again in every charging)...now its charging with this magnetic cable but slowly...my charger was old times showing 1,77 when s60 was charging...now only 0,75...next step is to change battery... waiting to arrive...after this, I'll change phone... lolxxxxx
door
I think maybe it id due to cable :) i had also issues in charging but after i put the little and fast cable from my powerbang it worked fine again
I have the same issue with my S60. The only way to recharge it is to use cordless charger (Qi charger).
+ other issues.
1 Opmerking:
Try charging it in your car. I occasionally do this and it charges fine. But, don't overcharge it, take it to around 88% and it should work fine.
Another thing I found is that the actual Doogee chargers break down, get something else that will charge up to 2 amps.
door
Having the same issue. Oh, Doogee. Why you gotta do this
Seems the charging issue is something reoccurring. My wireless charching suddenly stopped working on my S70 Lite. Cable still works, i have my S70 for 3 months now.
I had the same issue. Probably an issue with the USB connector of the mobile phone.
I replaced the loading PCB with a new 7USD one.
Works perfectly except that the microphone doesn’t work in handsfree mode anymore.
For rework you need to solder the speaker from old PCB to new one. And you will need suitable sealing material, since the sealing of the original PCB can’t be removed.
Obviously you people commenting “ it's the cable, try another cable” just didn't read my first few comments stating iv tried different cords, and what not. None of these comments are very helpful, does anyone know about why my phone randomly turns off,. Thats what id like help on more because doogee are so freaking slow to reply it's !#^&^$^ me off. What a $@$* arse company, and a $@$* house phone
1 Opmerking:
It's the usb connector on the loader board. Try another loader board.
For the restarts: Try another brand phone.
Or try unofficial Android if you know how to flash it and if you can live w/o fingerprint and some of the other features that 'break' at a few S60 when going to Android 8 (that's why Android 8 roll out was stopped).
door
Hi there
I had the same problem and more.
My fix for the no charging issue via USB was to factory and then Master reset the phone!!!
Voeg je antwoord toe
kadiriibrahimd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 8,687
