Ga door naar hoofdinhoud
Het eerste model van de iMac-lijn personal computers van Apple. De iMac G3 werd geproduceerd tussen 1998 en 2003.
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
Is dit een goede vraag?
Score 1
1 Opmerking
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
Was dit antwoord nuttig?
Score 3
8 opmerkingen:
That's modding, the MAC didn't have that built in.
door
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
door
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
door
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
door
3 commentaren meer tonen
Voeg je antwoord toe
Denny Tuckerman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 714
