Ga door naar hoofdinhoud
The Dyson DC45 is an upright cordless vacuum cleaner that is designed to pick up animal hair.
Why does my Dyson stop working every 3-5 seconds
We have a Dyson DC45. It shuts off (stops working) every 3-5 seconds. Can this be fixed, by myself or at a repair centre?
The Dyson DC 45 ( I have shown DC56 here as it appears similar to the DC45) stops every 3-5 seconds when in use. The following is a more detailed series of the events which occur.
The Dyson is fully charged, when starting use with the brush head attachment, stops working after about 10 seconds of use.
We turn it on using the trigger starter. It stops again after about 3 seconds. We release the trigger and press it again. It starts and runs for approximately 3 seconds, then stops again. The sequence of restarting is repetitive until we give up in frustration.
Is there a "home fixable solution" or must it be taken to a repair shop? If so, where in the Toronto area can it be taken.
Thank you
Is dit een goede vraag?
Score 17
20 opmerkingen
My disown work 3 or 5 seconds and stop working can I do anything L thank you
door
You need to remove the cone shaped filter ‘washing it alone isn’t good enough you need to remove the filter at the thick end there are 2 small clips that you can push in with a blunt knife to remove the filter sock from the frame!! Once you have done this you will see a large amount of dirt trapped in the filter frame remove the dirt wash and dry the filter sock preferably overnight clip the filter back together put it back in the machine and bobs your uncle
door
I have this same problem. Looked for this cone shaped filter and 2 clips but cant find it. Any help would be great.
door
Mine doesn’t have clips as such - but it has 3 little horizontal slots a few mm wide, that I depressed with the blunt end of a screwdriver. That was enough to pop the frame out of the sock thing, There was a plug of hair and dirt about an inch long and wide, jammed into the bottom/narrowest part of the cone!
door
brilliant it worked,why did I spend an hour on the phone talking to dyson and they couldnt resolve it
door
15 commentaren meer tonen
Voeg een opmerking toe
17 Antwoorden
Het nuttigste antwoord
I assume the battery is dead. Try a new one - you can get them everywhere online.
Pay attention to choose the right one as Dysons have quite different connectors.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Have the same problem - changed the battery and worked properly for a little while and then started to do the same thing again.
door
After mine stops I put it back in the charger for a couple of minutes than it works find. But would like it to just work. Any other suggestion ??
door
Try to open the cone shaped filter, as John suggested above. I did this just now and found a massive plug of hair and dirt wedged into the bottom end of the cone, that I would never have seen if I hadn’t disassembled it.
I became suspicious that the filter was the issue with my stop/start Dyskn, when I took the filter out initially and realised that the machine worked fine if the filter wasn’t in.
Do it - it’ll work!
door
carefully remove battery clean unit place in carrier bag, throw in bin ....buy a shark vacuum
door
There is a tab on the filter that wears down and stops it from running for more than a few seconds. Here's a video on how to check for that issue:
https://www.youtube.com/watch?v=9IUZ_Gol...
Score 2
It is the battery . You need a new one. My Dyson did exactly the same thing and I tried all of the filter cleaning and other fixes that were associated with this problem that were posted on the web. None of them worked. A new battery and it was as good as new again.
Score 1
1 Opmerking:
I did all the cleaning and it didn’t help. Got a new battery and it works like new.
door
Had the same problem. Charged fine and then stopped after 10 seconds. This isn’t a filter issue, it means the battery is dead. Bought a replacement on eBay for $45, good as new
I have a similar problem. When I pull the trigger, it continues to work but the brush head stops after a second. I’ve cleaned it thoroughly and it’s completely charged. One thing to point out is that when I remove the brush head and pull the trigger, it continues to spin without a problem. I just can’t figure out why it won’t continue to roll with the brush head on. FYI- I’m not talking about taking the head attachment off. I’m talking about tanking the brush roll off itself leaving the mechanical parts of the brush head attachment assembled.
2 opmerkingen:
I have had before its the stick attachment apparently it has sensors in it so may need a new stick part
door
Same issues With brush out it works fine. Seems like a lot of resistance in brush drive- cleaned out hair I found around the drive wheel and shot some silicone lube into housing and the cut outs were gone. If it happens again I’ll pull apart the housing on the head and put some lithium grease inside drive side and see if there is any other debris retarding rotation
door
Solved this 3 years ago with a new battery and I’ve ordered another. I’ll clean the octopus legs just in case but sure it’s the battery.
Ive no complaints with 2 to 3 years Per battery, just wish Dyson let people know. The on - off quick cycles are confusing and I’m sure many have ditched their Dysons in frustration.
i fix it when my wife says it’s broken. Doesn’t slow down like battery power tools.
My wife loves the vacuum.
1 Opmerking:
90% chance you just need a new battery!
door
https://www.youtube.com/watch?v=p3DgP1ci...
Had the same problem on 2 others. A recent post outlined a correction process by taking out the long tube filter, pressing the side holders back to release the cloth portion, and cleaning what debris might be in the bottom of the inside of the cloth portion of the filter… Brilliant on someone’s part!!
I had this problem too, and followed John Metrac’s advice about thoroughly cleaning the cone shaped filter. Sure enough, the filter was chocablock with dog hairs which I had to tweezer out! I had religiously regularly rinsed the filter under running water as advised in the manual, but never thought to investigate further. There was a whole border collie in there! Thanks John
I disengaged the long shaft and a green strong plant straw stuck in there. I pulled it out and it fixed the issue. Btw answers in this post were helpful!
Check the filter not the problem
Removed battery steal times and reinstalled works fine now
I think contacts on battery better now
What do you mean by battery steal times?
If all else fails remove the brush from your sweeper head and spray WD-40 into the drive mechanism for about 5 seconds using the plastic straw provided. This worked for me.
I had the same problem with my Dyson DC16 handheld. Forget about cleaning, this does not solve the issue
Here's the problem (see photos).
When you install the filter there's a tiny magnet that clings onto a hidden switch in a square plastic knob.
This hidden switch is not switched on after a while because the magnet is too weak.
Try it: Without the filter, the Dyson won't work UNLESS you apply a separate stronger magnet to the square knob.
The solution is to either insert a small magnet to the knob or opening the whole %#*@ thing (unscrew the housing) and permanently turn the switch on by inserting something behind it (a small pie
1 Opmerking:
Actually, I found out it is a fault in the circuit board, and cannot be fixed permanently. Dyson should take back all its products that have this fault, seeing there are so many complaints. But of course, they won't. Hope there's a clever lawyer out there who wants to take on Dyson.
door
I took apart the attachments -- small and large head of vacuum. The large head had hair wrapped around inner wheels and a lot of pet hair jammed inside different parts of the head. Once I cleaned it thoroughly it worked fine! Saved me buying a battery and/or a new vacuum! Spent nothing. First, see if any parts on your vacuum are obstructed. Obviously, in my case, that caused the vacuum to shut off after running for just seconds. So far, problem fixed. I watched a You-Tube video that showed how to step-by-step take the vacuum heads apart.
Yes , I had exactly the same problem. It was the battery that was bad. Sounds illogical I know, but I fittied a new battery and the problem was solved.
Any thanks I have just ordered a new battery will post on ere when I get it if it fixes the issue thanks again
Voeg je antwoord toe
Wally Turner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 68
Afgelopen 30 dagen: 298
Altijd: 156,438
