Ga door naar hoofdinhoud
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
116 Vragen Bekijk alle
My Amazon TV Firestick won’t turn on an Element TV
I brought my Amazon Firestick to my boyfriend’s house and plugged it into his tv. It won’t turn on at all. I’ve tried both HDMI ports, I’ve tried unplugging it and letting it “boot up”, I’ve tried turning off the tv, I’ve tried changing the batteries in the remote, I’ve tried “resetting” it and nothing is helping. It’s still plugged into the external power source. The screen just says no signal and stays blue. Nothing is popping up. What am I supposed to do?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Go to your TV settings and turn on the HDMI port. Also older models may not be HDCP compliant, like the Element TV (circa 2010?). In that case you'll need an HDMI splitter like View HD VHD-1x2MN3D. It will strip the HDCP copyright coding from the stream allowing it to show on that TV.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Can u show me what one looked like
door
I have my Amazon fire stick trying to hook it up to my nephew element tv how can i get it to start working on his TV
2 opmerkingen:
Plug it in to a USB port and plus the power cable to the USB-A port on theTV (if there, must be 5W 500mA (2.5W) or more) or into a power brick (reccomended, ideally 5+watts)
door
@casualgamer Thanks for the contribution, Conner! Minor correction though: *5V* 500 mA, lol
door
I purchased an Element 75 in goggle tv. My amazon firestick isn't working properly. My movies are distorted. What the solution to this problem?
Did you try a different hdmi port or the extended port the FS comes with?
Voeg je antwoord toe
Codi Sp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 47
Altijd: 18,238
