Ga door naar hoofdinhoud
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Cracked Screen on Phone
Hello,
today my phone fell and my display glass broke (Samsung G. S3 Neo), the display normally works, but I have a big crack there. I do not want to put my phone in the repair shop, so I wonder if it can not get worse or something, and that the display will stop working.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
There is always a risk of the LCD or the digitizer breaking a short time after the glass. It may be best not to press your luck, back up the phone, and purchase a replacement.
Was dit antwoord nuttig?
Score 1
eseesntially, that depends on how you handle it.
yes, the display can get worse. depending one if you put pressure on the screen, or drop it again. The crack will impose what is known as the "notching effect" and cause issues. that doesnt mean it will though. if it is handled with care, it shouldnt get worse.
Score 1
You will need to replace the front glass. Check this out, it should help: Samsung Galaxy S III Broken Front Glass Replacement
Score 1
Voeg je antwoord toe
VNTG WTSK zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 126
