Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
20 Vragen Bekijk alle
power button pin out?
i cant find the pin out for the Power button flex. can someone highlight the two leads for the power button? im trying to diagnose a phone that wont turn on, but i dont have a spare button to compare it to.
thankyou.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
xxx
xxx
x2x
1 + 2 =power
Was dit antwoord nuttig?
Score 3
1 Opmerking:
is there ANY chance you know what "O" does in the below example? the pin on my board that lines up with O is missing, I'm thinking to use a donor board and get someone to re-solder it on...
x
xxx
xxx
xxO
door
the top pin and the bottom middle pin… use the volt meter on continuity mode and click the button until it beeps while you are pressing it !!! BOOYAH
You are god
No good
Just god
Tnx alot
Voeg je antwoord toe
Scott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,451
