Ga door naar hoofdinhoud
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Vragen Bekijk alle
How do I remove a (somewhat stripped) screw that is stuck?
In order to replace the palm rest I have to remove all the internal components but a few of the screws holding the motherboard in place are stuck.
How do I remove this screw without damaging the motherboard?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like you used the just slightly wrong sized philips screw driver.
This probably caused the stripped screws.
You can get a set of strip screw removal tools.
https://www.amazon.com/Moody-Tools-58-06...
Or if you have a small enough dremel you can simply remove the heads of the screws.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jelle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 654
