Ga door naar hoofdinhoud
Released in September 2013, this 7-inch 1440x900 tablet running Android Jellybean was sold by Tesco. It was discontinued in October 2015 having been superseded by the Hudl 2.
6 Vragen Bekijk alle
Tesco Hudl 1 - blind factory reset
I have this Tesco Hudl 1 which a friend literally found under a hedge, and gave me to see if I could fix it. It takes charge and if you try to power it up there are signs of life (faint screen backlight glow) but no display. However if you plug in an external HDMI screen it produces a display, and even responds to a mouse and keyboard plugged into the USB port. But it boots to a lock screen and I've no idea what the password might be.
I tried a replacement screen but it was no better. Presumably the problem is with the LCD driver. However, it'd be neat and an interesting challenge to get it working with the external screen, mouse and keyboard and possibly to root it.
It should be possible to do a factory reset by pressing the power and volume-up buttons, which should show the system recovery menu, but unfortunately this menu is not displayed on an external screen, and I don't know how many times to press Volume Down to get to the factory reset menu item.
Could someone please tell me the system recovery menu structure and the precise sequence of button presses to do a blind factory reset, including any delays necessary after releasing the power and volume-up buttons before the system recovery menu appears.
Is dit een goede vraag?
Score 5
5 opmerkingen
Hi @pleriche ,
The info in this link may be of some help
Cheers
door
Thanks. I downloaded the package in that thread and followed the instructions, but whatever I do I can't get the RKAndroidTool to detect the Hudl, even though Windows sees it.
That thread seems to have been silent for over 2 years but I posted a question nevertheless - probably my best hope.
Regards - Philip
door
Sorry for the delay but have now finally got around to it! Details here http://www.tutorscreens.co.uk/hudlreset....
Hope it helps!
Anthony
door
How do l get my hudil bactk I but ssi in not working
door
How do I get my hudil back I put password notting
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you still after this sequence - I have just had to go through it with a hudl plagued (still) by ghost touches so no problem to do it again and write it down. AW
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I'd more or less given up on it, but it's still sitting in a box and if you can let me have the sequence I'd certainly give it just one more try - thanks!
door
Voeg je antwoord toe
Philip Le Riche zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 18,208
