iPhone stuck on red battery logo screen
My iphone died completely and turned off. So it's been 3 hours charging and it's not turning on, it's totally just stuck on the red battery logo screen. I was thinking about restarting it or put it in dfu mode, but there are two problems: 1) my home button isn't working, 2) it's turned off so it's not detectable to the pc
Anyone got any idea how to fix that?
Is dit een goede vraag?
omg thank you for this!! I had the same issue and took your advice but propped it up next to my space heater for a minute and boom! Fixed it. Thanks again!!
door Jessica Jones
It will sound incredibly peculiar, but years ago, my father gave me some old stock wristwatches, all in working order. After a plane ride home, they didn't run. Dad said to lay them, face up, on an electric heating pad for a little while. Voila! We supposed it had to do with a lubricant seizing up. Have not had the same issue again. Old Wives and Good Grandfathers' tales are the best
door donna
I was able to get out of this case by following the above steps..
Plug in iPhone into USB on PC
Hold the home and power button together until screen is black. Release the power button and only hold the home button until iTune symbol appears.
Now, unplug the iPhone and plug it into the wall charger, NOT the USB charger on PC. This action allowed the phone to keep charging without entering the boot loop
If the Apple logo reappears, then try step 2 again.
The phone will clear itself and power again with the login screen.
It worked for me in less than an hour.
https://bit.do/eV86o
door MelissaRycroft
@melissarycroft (06/24/2019)
Wow, thanks! I wasn’t expecting this to work but it was the only thing that fixed my iPhone SE which was stuck on the red battery and would not power on.
Many thanks!
door Ben
Thank you so much! I was having the same issue on my iphone 6 but the hairdryer tricked worked. I had to try it twice because I thought my phone cover would be thin enough to transfer the heat but I guess not because when I tried again without it, the apple logo came up instantly!
door Abigail Thomas
6 commentaren meer tonen
