My sound turns off after about 20 seconds of watching.
The sound on my Rca tv turns off after 20 seconds of watching. I can turn the tv off, and back on, and the sound is back. Again,it cuts off the sound after about 20 seconds. I tried unplugging for awhile, and the reset from the menu, and the reset by holding down the power button while unplugged. Still did the same thing. Any thoughts??
Is dit een goede vraag?
Hi @renaecd ,
What is the model number of the TV?
Where is the volume level slider position when the sound cuts out? If it can be shown by pressing the volume up/down that is?
Does this happen on the other different signal input types of your TV e.g. HDMI, AV, Co-Ax, whichever type that you are not using with this problem?
Does the TV have an earphone socket or the option to select external speakers to see if you lose sound from these outputs also?
door jayeff
Yes, it happens on all the inputs. The volume is low to medium. I will look up the model number and for an external speaker socket.
door Renae
