Ga door naar hoofdinhoud
The DOSS SoundBox can be identified by its model number: DOSS SoundBox on the base between the feet of the speaker. Its a fourth generation bluetooth wireless audio player that was released in 2016.
24 Vragen Bekijk alle
The port on the doss speaker wont illuminate and the port seems like j
I try to change my charging cords to charge up my doss but still no LED light comes on . And idk what happen to my lort because it wont charge .
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
hmmm, what model of doss speaker are you using? Ifixit has a special forum for it kindly refer to this link if it helps. But I think the main problem is on the charger itself a common problem in some devices.
Was dit antwoord nuttig?
1 Opmerking:
there is nothing on the device page.
door
I went ahead and opened up the DOSS SoundBox Color Portable Wireless Bluetooth Speaker and found that the little ribbon cable that connects the speaker to the actual board with the charging, 3.5mm Jack, and reset button is damaged. It seems that the contacts have stripped off in the connector that is soldered onto the board. If anything I would either try to contact the manufacturer or just purchase another or different unit.
1 Opmerking:
I stop turning on the lights
door
The battery died. I had the same issue but I only had my for 4 months. They have a year warranty, so I got to get a new one for free and got to keep my old one
Voeg je antwoord toe
Allen Murray zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 17
Altijd: 2,363
