Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Wifi/bluetooth iPhone 6s Plus
I recently replaced the loud speaker on a iphone 6s plus. Once I put it back together the wifi and bluetooth only worked intementantly and was weak. I took phone back apart and checked all connections and couldn’t see anything wrong. I started putting things back together and was able to get it working again. Now it’s been a few weeks and its back to dropping signal again. My thought is I may have damaged wifi/bluetooth cable, but I also notice several other “wifi” cables and I’m not sure where to begin. Nothing looked off so I’m struggling to figure it out. In the repair guides, I’m only seeing the one cable listed as both wifi and bluetooth so I’m thinking that’s it. Am I thinking correctly? Everything else including cellular is functioning properly.
Is dit een goede vraag?
Score 1
2 opmerkingen
My 6s plus only gets a weak 5ghz WiFi, no 2.4ghz. Doesn’t discover Bluetooth but does pair with Bluetooth speaker and plays music. This happened after a housing swap, I have since quadruple checked all my antenna connections, even swapped antennas but no luck! Any ideas????
door
Same, Jimmy.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Jason
My first guess would also be to check the wifi:bluetooth antenna is plugged in well. The coaxial connectors can be very tricky and might seem 'clicked in' while they are not. They are also very dust sensitive so best clean them with some rubbing alcohol.
Look at step 47 of the repair guide. The connection is on the bottom of the motherboard so it's easily overlooked that the antenna is dangling loose or not clicked in 100%
iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
Love to see new users being so helpful right off the bat. Upvote from me!
door
i cannot get that part to “click”. it is like trying to snap a jacket that just will not catch. i even took the antenna off so i can try to click it to the logic board without having it attached to the back. no luck! i can get other wires to snap fine but not this one with the ribbon cable. any tips?
door
Voeg je antwoord toe
Jason zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,564
