My kenmore washer elite spinning slow.
my washer was not spinning at all and i found a penny jammed between the tub and agitator. the washer spins now but will not spin fast enough to get all the water out...
Is dit een goede vraag?
Make sure the water is draining properly. If the water does not drain out, then it could cause the washing machine not to spin. Check all the drain hoses for any clogs or kinks. This is easily done by disconnecting the drain hoses and doing a visual check for clogs or kinks
Check to see if any belts have came off or are loose. Unplug the washer and pull it away from the wall. Use the screwdrivers to remove the back panel. Visually check for any broken or loose belts. Replace any loose or broken belts.
While the back panel is off, visually check for any loose or missing bolts on the motor or drum. If any are missing or loose, tighten them and replace the ones that are missing.
If everything has checked out to this point, then the water level switch could be bad or the water level hose could be clogged. Remove the front panel of the washer and locate the clear tube going from the tub to the water level switch. If lint or debris has gotten into the water level hose, then the washer may not spin fast. Clean the debris from the hose by blowing on the hose or tapping it on the side. To check the water level switch, go to the back of the washer and locate the back end of the water level hose. Use the voltmeter to check to see if the water level switch is getting any power.
If the washing machine still doesn't spin fast enough or doesn't spin at all, then it is time to call in a professional washing machine repairman.
Was dit antwoord nuttig?
We did. Will pump out but won't high speed spin.
What is the model number of the washer?
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 113
Altijd: 14,793
