Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 - Home button works but touch ID doesn't
Hello mates, so, as the I said in the title, I replaced an iphone 6 screen and then everything was fine except the screen because of some pressure marks so I unsrewed everything and did it again like 3 times and now the touch ID doesn't work anymore but the home button still working fine! Already made a hard reset, tried dfu mode everything,still doesn't work.
Some pics of the home button connector :
https://imgur.com/QMwP3Zt
https://imgur.com/8AHbU7D
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
fixed it by replacing the extension cable that runs from the home button to the display connector area.
Was dit antwoord nuttig?
Het nuttigste antwoord
Have you tried replacing the longflex, running along the screen? Have seen other cases where repeated removal / several screen replacement causes this.
Score 1
Voeg je antwoord toe
André Jóia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 455
