Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
Why my Battery drains so Fast?!
Hi there!
I have an iPhone 5S which I traded a broken Galaxy S6E for.The phone looks good, problem is that the battery drains a bit quicker than expected. It gets a bit warm but very little. It continues to drain overnight or in my pocket, Wien 20/30/40% randomly shuts down and it doesen’t accept all the cables. He gave me the original cable which seems to work for now.I’ve read on the Internet that it may be iOS 11.2.1 that causes issues, but not sure.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If it dies fast and you tested the battery, you have a faulty U2 IC chip and needs to be replaced and resoldered!
A board level technician will be able to replace it for you!
Also using third party cables and modified cables can also blow the U2 IC Tristar chip on the board and you get those symptoms!
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Check the health of the battery using one of these:
Windows: 3UTools
Mac OS X: Coconutbattery
iOS: Battery Life
If your battery health is close to 80% or lower, consider replacing the battery.
You have a few options on getting a battery replacement, either by:
- Doing it yourself (DIY).
- Taking it to a mobile phone repair shop.
- Taking it to the apple store (booking a genius bar appointment).
Guide to replace the battery:
iPhone 5s Vervanging van de batterij
You can buy a replacement battery from iFixit here:
iPhone 5s Battery
Replace a 1558 mAh battery compatible with iPhone 5s.
5.92 Watt Hours (Wh), 3.8 Volts (V). Compatible with all iPhone 5s models. Afbeelding
Product
iPhone 5s Battery
$29.99
Score 3
3 opmerkingen:
https://imgur.com/a/K4WhZ
Battery life seems ok I think...
door
Yeah battery life looks okay.
Backup your phone first, then do an restore via iTunes then restore from iTunes backup, sometimes this helps with rapid battery drain when the battery health is good.
iTunes backup stores your photos, contacts, settings and some app data. You will need to sign in to certain apps again after restoring the iPhone.
door
I've already done that, from what I see, instant amperage is pretty low (120mA)... maybe is because my cable was repaired. Anyway, I'll be swapping the back case with all the components soon and I'll post a comment here as an update if I fixed anything. Have a great day !
door
Stay away from the ‘Battery Life’ app… it’s a total rip off, and will tell you nothing more that what you already know about your battery. It gives absolutely no info on ‘wear and tear’ percentages etc… all it will tell you is how much % in charge it has left, which of course you already know! The better app to get is ‘Battery Testing’.
Score 1
Voeg je antwoord toe
Andrew Drift zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 14,388
