Ga door naar hoofdinhoud
Sony Xperia Z3 Dual also known as Sony Xperia Z3 D6633 is announced in September, 2014. It features 146 x 72 x 7.3 mm (5.75 x 2.83 x 0.29 in) body, IP68 certified, 5.2 inch display and 20.7Mp rear camera.
27 Vragen Bekijk alle
There dust on camera sensor, cannot get rid of it..
Hi! Very helpful video! I have dust on my camera. I tore don the phone, cleaned the lens and used a rocket blower to blow the dust but it stays there. When I remove the main camera and move it around, still connected, the dust particles do not move with the picture , therefore the dust must be somewhere else inside the phone... Seems its on the sensor and the sensor is not part of the lens. Is this correct? Any ideas where this dust might be? Thanks for any help!![http://file:///Users/oisingormally/Downloads/DSC_0001.JPG]
Update (12/07/2017)
Thanks again Scott!
Here is a quick video. The camera is still connected but is out of the phone so I can move it around.
YesterdayI was convinced the dust spots did not move with the camera and I thought the dust was somewhere else than the little camera module.
But now I think you are right, I will order the replacement camera !
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
so there are two lenses relating to the camera.
there is the Shielding Lens, which keeps dustand debris out of the camera
and the Zoom lens, which is the actual lens of the physical camera
if you are getting the smudges with a perfectly clean shielding lens, then the zoom lens is likely scuffed by the dirt that was in there.
Replacing the camera will fix this issue.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you for your reply! Is this shielding lens and zoom lens within the camera itself? How can I upload a short video/ pic, so you see whats going on?
door
there is a media content selection while editing the original post. (Add photo)
The Shielding lens is the glass that is attached to the Back Panel of the phone.
The Zoom lens is manufactured into the camera module itself.
door
Voeg je antwoord toe
oisin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 1,138
