Ga door naar hoofdinhoud
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
Why does my headphone keeps beeping very frequently?
I have Skullcandy Hesh 2 wireless headphones which keeps beeping in duration of every 5-7 min even when its battery is more than 50% . Please help
Is dit een goede vraag?
Score 13
8 opmerkingen
Please Help my bluetooth headphones left side always makes a beep sound when playing something or whenever the headphone hears a sound played on it .it is very annoying please help..it does not fix it like the low battery etc
door
got the skullcandy corded headphones and it would make those "grounded-like" noise :( what doi do with it?
door
My bluetooth headphones keep saying “your device is connected” and beeping nonstop. The voice is every 2-3 minutes, the beeping is every 30 seconds
door
Any luck? My skull candy hesh 2 r doing the same thing sooo annoyed
door
I have blue tooth candie couture headphones, and they're beeping, even though I charged them all through the night, and won't stop even after I tried reconnecting them to my phone.
door
3 commentaren meer tonen
Voeg een opmerking toe
16 Antwoorden
Filteren op:
Het nuttigste antwoord
Pair the device again. Both the device and the headset. Skullcandy headphones make this noise not just when the battery is low, but also when it becomes connected without pairing (like starting music on a nonprimary device that it had also been paired to).
In short, redo the bluetooth connection, that should fix the beeping
Was dit antwoord nuttig?
Score 8
4 opmerkingen:
This seemed to do the trick. I haven’t tested them fully to see if the problem persists. The issue is unpredictable, but so far it seems to hav stopped just from forgetting the device and re-connecting
door
My issue was for the ink’d wireless 2 earbud though. So it seems like it’s a problem with several skullcandy headphones.
door
Thank you so much! Worked for me
door
Yeah! And what causes that, to beep?
door
hi i also have the same problem before but thru research i learned to just holding the volume up or down to stop the beeping sounds. connect to it to your phone and then hold the volume up or down. just try it. works on me. ☺
Score 8
12 opmerkingen:
This really works! I pressed and held the volume up button and it stopped beeping!! Thanks!!
door
Thanks a lot! It works on mine too.
door
It's not working on mine... ☹️
door
It’s not working
door
Mine too it wont work
door
7 commentaren meer tonen
It does that to let you know your volume is too high.
Score 3
3 opmerkingen:
To fix it just turn them down and it’ll stop.
door
I muted it but it did not work
door
Fixed my problem. I tried everything above turned it down one click no more beeping.
door
I found a button pressed (i.e. stuck in and broken) and not returning due to spring failure beeps every 2 seconds. Manually pull button out.
Score 1
As far as I know beeping is only for a low battery indicator.
Sounds like you have faulty headphones.
I would contact Skullcandy on repair or replacement.
https://www.skullcandy.com/customer-serv...
1 Opmerking:
I fixed it. For phones with Qualcomm processors switch off aptx codec mode to most stable connection mode in blutooth settings in phone.
door
For me during conference call, Mute/Unmute/Mute your phone, and ++volume on headset. The beeps ended there.
1 Opmerking:
It didn’t work for me appreciate the info! My Iphone Had 5 got a 11 still beeps after call if I don’t answer it tried volume didn’t work ;(
door
I have the same issue with Skull Candy… I suspect it’s our internal bloatware, it only seems to happen on my work machine. I think our firewall is blocking it, because after I get this it won’t connect again. Very frustrating.
One side of the ears want slides up like it used to do.
They are overheating give it a while
2 opmerkingen:
Feel the right part of the headphones and boom problem solved
door
One of the volume buttons are stuck, pry it up without breaking and it should stop the beep.
door
Beeping solved on iPhone bluetooth
Simple- turn off all haptics settings when listening to music. For some reason some haptics are triggered.
It may be , because of your settings.
My problem solved when I changed the settings.
  1. Go to settings.
  2. Then click Notifications
  3. There will be a list of apps which recently sent notifications. Found Android System among them and open it.
  4. Scroll down and look whether the option “ Apps are using mobile data “ is on.
That was my problem. After I turned it off everything became alright ?
Wash the bt circuit board with wd 40 or petrol and scrub with tooth brush gently wash it again with petrol and leave it for dry when it's dry reassemble headphones and enjoy ur own maintenance why bt headphone have beep sound because sometimes carbon can make buzzing humming sound I have done this process and it's really works
hii im also face this problem this website is helpful for me
there are 8 reason 1st technical issue wiring
i suggest you this website it will be helpful for you
Update (11/29/2022)
hii im also face this problem check this steps
low battery sign distance between the device and headphones technical problem in the headphone check this website
it will be helpful for your headphone im also clear this problem from this website
I have DOQAUS care 1 headphones and when I turn them on they keep making beeping sound and not letting me lower problem I have tried reseting it but it doesn't work
Mine are cat headphones and also mine keep saying low battery please charge
My model number in the back of the case ar-tws200226 and mine beep every minute then die
Voeg je antwoord toe
Kartik Gupta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 155
Altijd: 163,342
