Ga door naar hoofdinhoud
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Vragen Bekijk alle
Spilled coffee on MacBook Pro Late 2013
I spilled coffee over the keyboard about a week ago. I immediately wiped down the surface. Once everything was dried off I noticed the MacBook was no longer able to turn on unless it was plugged into the charger. Later in the day I also noticed it performing much slower and was slightly glitchy but still able to function. I don't know a lot of computer terminology but I would would think I need to replace my battery and perhaps something else. Any recommendations? Trying to save money if I can and not buy a new laptop.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Any time you spill liquid on a laptop, the last thing you want to do is give it power or turn it on. The first step is to open it up and remove the battery. The next step is to remove the logic board and carefully clean any and all liquid off of it and check for signs of corrosion (if you do this right away then there may not be any corrosion yet, although most of the older Macbooks I see have some kind of corrosion on them regardless of history).
You'll probably need a new keyboard at the very least. Cheap and easy if you're handy with disassembly. I doubt you'll need a new battery but if the charger still doesn't work you may need a new one and/or a new Magsafe DC board.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ari Blonder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 602
