Use a 5c or 5S battery temporarily for data recovery
Is it possible to use a 5c or 5S battery temporarily to recover data off a iPhone SE? I have no problem hard wiring it if needed instead of using the battery connector
Is dit een goede vraag?
Sure! The connectors don't match but it's still the same output voltage; just solder some small jumper wires. Double check with a voltmeter to insure you have the polarity right.
Another alternative is to use a DC power supply if you have access to one.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 44
1 Opmerking
I do have access to a DC power supply. All I need is +/-? Not the gas gauge or anything attached?
door jjones0377
