Ga door naar hoofdinhoud
Replace I3 with i7 logicboard?
Hi ,
I would like to replace my i3 Logicboard with i7 Logicboard. I already replaced it, but i have problems with the Keyboard and the hdd logic cable different ( i3 smaller pin ) . I'm not sure, but the CPU cooler is not starting to rotate , but i`m not sure.
PLEASE for SUPPORT . 10x in advance !!!!
Is dit een goede vraag?
1 Opmerking:
Download MSI Afterburner and see if you can get any rotation.
door
Voeg een opmerking toe
1 Antwoord
The logic board (motherboard) could be damaged or it does not support your computer with the upgrade. Is the logic board the same brand as your old i3 logic board? It could be a software problem with the change of the logic board so maybe a motherboard bios update will fix the issue.
Was dit antwoord nuttig?
Voeg je antwoord toe
Christo Emilov zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 298
