Ga door naar hoofdinhoud
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Vragen Bekijk alle
Problem tearing apart iMac
I’m disconnecting my logic board. I can’t get the dc power cable to disconnect. I can push in the sides but can’t get it to unplug. It hurts my fingers too much. Asked hubby, he can’t get it to unplug either. Is there a tool I can use? Or would I be able to use a towel or potholder to help?
Is dit een goede vraag?
Score 1
2 opmerkingen
There must be a tool that can be used, other than the plastic tool recommended. It won’t work.
door
Got it unplugged. Proceeding with repair. We used a pliar with plastic coating. My got it unplugged.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Nothing really to grab other than the connector shell. Pulling on the wires can damage the cable and lifting upward can damage the logic board connector.
The trick is to hold the clips away from the mated catch and then pull straight out. Since you have a second person you could have one person holding the clasps the the other either pulling the shell or use a pair of plastic pry bars iFixit Opening Tool to wedge in the slot where the connectors break apart. Once you get them in (one on each corner) carefully pry them to the sides in a circular motion Think how a dial gage needle (speedometer) moves on the flat plane, thus the gap slowly grows to the point you can pull the connector free.
iFixit Opening Tool Afbeelding
Product
iFixit Opening Tool
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ladycerridwyn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 64
