Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 Vragen Bekijk alle
Should I install a backlight in a gameboy advance sp?
I have a Gameboy Advance SP of the model AGS 001, but want a better screen. Should I attempt to do this? Does replacing the ribbon have any other effects? Should I just buy a new Gameboy Advance SP that has a brighter screen?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Is the screen too dim, I would not recommend to get new one or to get the display replaced
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I am considering modding my GBA instead.
door
oh then its fine
you can do it if you are fine with it
door
Het nuttigste antwoord
The ribbon connectors are different between the two models, if you want to replace the screen, you're going to have to get a pesky adapter that is really hard to fit into the shell. I recommend just getting the 101 model, it's a lot easier and if you find the right place you can get it for under $40. Hope this was helpful.
Score 2
Voeg je antwoord toe
Asta Ulrikke Haugnes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,781
