Ga door naar hoofdinhoud
A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
569 Vragen Bekijk alle
PS4 Slim takes multiple attempts to turn on
Hey
I have a PlayStation 4 Slim 500gb(CUH-2016a) and has bit of a problem.
When I turn it on, 8/10 times it beeps, gives blue light and turns off. I have to switch off the outlet, wait and then turn the outlet on then attempt to turn on the PS4. If I don't turn off the outlet and press the power button there's no response, no blink or beep, completely cold. Sometimes it turns on in 1 attempt or sometimes even directly, sometimes you have to repeat the process 5-6 times. (Doesn't matter if you turn on from power button or controller)
When it turns on it works perfectly fine. Does not power off or anything. I have re-initialized it but problem persists. Also changed the power cord but to no use. I suspect a power supply issue. Any ways to resolve it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Sounds like the power brick is faulty, unfortunately there is no guide on how to replace this on fixit but you could follow the teardown video for a rough guide on how to replace this.
Was dit antwoord nuttig?
1 Opmerking:
When you say power brick, does that mean the whole power supply or one specific component within that?
door
Need help
Have you solved this exact issue? I had to replace my old PSU because of this back in 2017 and now here I faced the same issue on the second PSU and don't know what to do with it other than replacing…
Voeg je antwoord toe
Saad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,749
