Is it really the inverter board?
I've read many questions, answers, etc. dealing with display inverter problems, whereas in most cases the display beacklight wasn't working at all or was flickering because of mechanic problems.
So I have almost the same problem with one difference: in general my backlight is working, but only at lowest level. As soon as I light it up with F2 button, it breaks down. If I bring it back to zero (with F1) and then 1 up, it comes back.
When the laptop wakes up from being closed before, it usually as well breaks down and needs to be resetted to lowest level (as explained before).
So I'm curious whether this could really be the inverter, as most people say that a bad inverter causes completely dead backlight. And it doesn't seem to be a mechanic (cable) problem, as it has nothing to do with the screen angle. But: sometimes when resetting it from 0 to 1 it is flickering and crashing then again, so I have to try the described routine for 3 or 4 times until it works.
My model: http://www.ifixit.com/Info/ID-your-Mac/3...
Meanwhile I already opened the macbook to check if I can see any cable damage or loose connectors - nothing.
So what do you think: is it really the inverter? Or, as it seems to be dependent of F1/F2, rather software? This is a 2 GHz Santa Rosa machine.
THX a lot in advance for any help!!
Is dit een goede vraag?
4 opmerkingen
ok guys. so i finally got to buy a new inverter board from ifixit and ... it didn't work :( still the same problem ... althought now after several weeks of driving my display on lowest level i again can use it on somewhat around mid level without suddenly losing backlight. my next try will be with a new cable :( 55 bucks for nothing..
door txt
i have the exact same model and exact same problem
let us know if replacing invert worked for you!
door white rainbow
I suggest you start your own question as we've had no response from the poster for a week.
door mayer
yo, sorry for not answering so long! as posted above, i'll get a new inverter board as soon as i have some spare money. i'll keep you guys updated what's the result!
door txt
