Ga door naar hoofdinhoud
This model was released years ago and continues to be produced. The disassembling is straightforward as long as you follow the instructions.
8 Vragen Bekijk alle
How do I take off the rubber grip.
I see how the hands pictured in all the guides for the dis-assembly of the Wahl Li Trimmer, but I don't know what to do with them. I realize this is very basic, but I need to know each step of the dis-assembly process.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
I just figured out a way to take off the grip sleeve. First point is that the picture of the hand in the front was misleading! There is a thin gap between the head and the grip sleeve. I turned the trimmer so the back faced me. Stuck my fingernail into the gap, then slid it under the Rubber Grip Sleeve. Then pulled the sleeve up off the handle and down toward the bottom to create a flap my fingers could grab. After that I gently slid one hand to the front side so fingers were able to replicate the hand at the back. I pulled down gently keeping in mind the switch in the front.
Was dit antwoord nuttig?
Voeg je antwoord toe
P.I. Mort zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 300
