Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Point-and-shoot digitale camera.
The flashlight doesn't work
I followed the 'problem' steps from the manual, but the flashlight is still not working.
before it stoped working, from time to time the flash worked, making a popping sound when making a picture.
I think, it is broken and needs to be replaced. but how, do I do that? and were can I find a new flasher?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Your best bet it to put a watch on eBay for a "spares or repair" camera of the same model but with a different fault. It should then be possible to swap out the flash module. You can practice disassembly on the one from eBay before attempting yours.
BUT: make sure you understand the danger from the flash capacitor and how to avoid it - this can hold a charge at a dangerous voltage for many hours, or even days, after being switched off.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
olé kike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 561
