Ga door naar hoofdinhoud
Sony Xperia Z4 (known as Sony Xperia Z3+ in Europe). Smartphone with 5.20-inch 1080x1920 display powered by 1.5GHz processor alongside 3GB RAM and 20.7-megapixel rear camera. It was released in 2014.
20 Vragen Bekijk alle
Need help with identifying missing motherboard component (resistor?)
Hello and Good day to you everyone,
After replacing the LCD, the phone boots and works like it should, the LCD lights up and touch seems to work as well BUT no display (nothing comes up on screen)... went back to check on the motherboard and found this 'melted' component, which I don't know what exactly is or if it is replaceable or not... Help me identify the component =)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I don't think you will find the answer here with board level repair, you will need to try a gsm forum where they specialise in board level. You will either find the identity of the component or a way round it by jumpering it by soldering wires to the board.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Abderrahmane Rahmani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 311
