Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Vragen Bekijk alle
Replacement iPad Air screen spazzing
I’ve had my screen replaced 3 times not by Apple but due to the screen unsticking which I later found out that company bent my frame, It’s now started to spas out by itself so I can’t touch it or type anything. Does anyone know a fix before I buy a new iPad? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Ghost touch on Airs and Minis is due to the company not insulating the edges of the digitiser, so it shorts against the frame and causes touch to work by itself or cut out.
See this answer for details Digitizer activating itself after digitiser replacement
Was dit antwoord nuttig?
Score 3
Take it to a more reputable repair place. Ghost touching on a screen is common with cheap screens. If you use a high quality screen, and high quality adhesive (along with good repair and frame cleaning practices), you will get a screen that doesn't lift and works like it should.
Score 1
1 Opmerking:
The only problem is a it’s more expensive to replace than my iPad is actually worth, is there a cheap solution?
door
Voeg je antwoord toe
wlmsslsmskal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 284
