Ga door naar hoofdinhoud
De Huawei Honor 8 is een Android-smartphone die in 2016 werd uitgebracht en beschikt over een 5,2-inch 1080p-beeldscherm, 4 GB RAM, dubbele 12MP-afbeeldingssensoren, een vingerafdruksensor en een USB Type-C-poort. Model: FRD-L04.
Can't perform a factory reset
I have forgotten my password and as a result I am unable to reach my settings. I have not performed a back up and I have holiday photos on my phone I would like to keep. I have tried to perform a factory reset but I have been unsuccessful. What should I do?
Is dit een goede vraag?
1 Opmerking
If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@preheat If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right . If you get locked out after to may failed attempts then go here then instead of factory reset in step 4 select wipe cache partition. do that and you will get a new round of password attempts . If you made the password you will eventually get it . Hope this helps
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Tryn to rest huawei android to factory settings but im stuck on formatting/data
door
It bypasses the scrolling option to wipe data
door
[] Turn off your Android device. ...
[] Press and hold the "power", "volume down", simultaneously. ...
[] Release the buttons once your Android device is powered on. ...
[] Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.
Score 2
4 opmerkingen:
This will cause lose of holiday photos
door
yeah i concur... but assuming he cant remember his password how much choice does he have? he can keep trying though until he gets the correct password. And hopefully if he has to reset the device, he has a back up for his files.
door
I hope you dont mind I made a correction to your answer I removed the camera button part as this was incorrect but the rest was good
door
yeah I appreciate it man,... tnx
door
hi, i have reset my honor 8, and now the first steps to log in with gmail account, but i cant continue because wifi is not turnin on!! i cant solve this problem. please help me :(
arberim_d@hotmail.com
Voeg je antwoord toe
Lexi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 10,094
