Ga door naar hoofdinhoud
Why does my phone restart after startup...
When I sometimes power on my J1 Ace, I do my password but nothing happens, at this point I can't power off no'r turn the screen off, It's basically frozen. After 30s-1 minute,
The phone does a re-boot and sits on the slow flashing samsung for awhile then loads.
This may have to do with storage or something, But I have no clue...
Any Ideas?
Is dit een goede vraag?
Score 2
3 opmerkingen
Bump Post Bump
door
Did you improve the information given after you bumped or checked your spelling? No-one could answer it before.
door
Well I was hoping someone could at least try help
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds a bit like a boot error try wiping the cache partition This will clear the boot memory so you get a clean boot . Try it and let me know . If all else fails do a factory reset but remember to back up your data. This video shows how to hard reset or factory reset https://www.youtube.com/watch?v=IdwT5fQS...
instead of doing the reset go down to wipe cache partition and do that first and see if that brings joy . If you get no joy then a factory reset will probably fix it but again remember to back up your data and contacts as a factory reset will wipe it clean . And @mayer I wasn't online yesterday so the bump did help and Brayden hope this helps
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I will try this @jimfixer Thanks!
door
Did you update your phone? from phone update through internet?
Try to Downgrade your ROM Version.
1 Opmerking:
Haha, I finally ended my Phones life. (Dropped on a Sidewalk xD) . But it seems to be a rec curing factor in these models... Oh well.. Thanks anyway!
door
Voeg je antwoord toe
Brayden Anderson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 1,319
