Ga door naar hoofdinhoud
Apples herziene laptopreeks uit 2016 gericht op professionele gebruikers. Beschikt over een 15-inch Retina-display met 2880 bij 1800 pixels, quad-core Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB opslagopties, 16 GB RAM en een toetsenbord uitgerust met een Touch Bar. Uitgebracht in november 2016. Beschikt over model A1707.
Snap sound from hinge
When MacBook heats up and cools down I get a snap sound from the lower middle of the sceens hinge. I can also induce the sound by running finger along black strip that has MacBook Pro printed on it. Once it does it, it doesn't seem to repeat until the temperature changes again.
Has the MacBook not been assembled correctly? And if I live with the annoyance, will it eventually break down and kill the computer?
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
I would bring it in to an Apple Store so they can either fix it or replace your system.
Remember you bought the system as working not having a defect. This is a defect which Apple also needs to know about as well so they can correct there building process.
Was dit antwoord nuttig?
Score 2
I have this problem too!
I found this video as an example of the issue (I’m not the owner).
It always happen after few minutes of use. Sometimes the popping noise was so loud that I was able to feel it if was using the touchpad.
Don’t buy this computer if you plan to use it during meetings, public speaking or studying in silence. It’s really annoying.
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,857
