screen becomes black when half open
G4 Screen turns fully black when half open. Works until half open.
Is dit een goede vraag?
Inverter cable has to be replaced.
Was dit antwoord nuttig?
Please give the last three letters of your serial number so we can tell exactly which machine you have and give you directions to the correct part and guide.
The inverter cable is not the same in all ibook G4 models that's why mayer wants your machine serial number. Is it a 12" or 14" model and what's the processor speed (800mhz, 1ghz/1,25ghz/1,33ghz/1.42ghz) ?
+ How to replace the cable:
iBook G4 12" 800 MHz-1.2 GHz Inverter/AirPort Cables Replacement
Here's the part: [gekoppeld product ontbreekt of is uitgeschakeld: IF183-000]
Thanks for the helpful information. We will give it a try. I will write again if we have more questions and I will let you know if it works!!!! Randy
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 947
3 opmerkingen
Thanks for responding. I am having a challenge getting the keyboard to come off to get serial number. When I get it, I will send the last three letters of the serial number.
Thanks,
Randy
door Randy
Mayer,
Thanks for the answer. Finally got the keyboard off.
It is an iBook G4.
Last four letters of iBOOK number is: BT/LL This is the number on the left side below the ethernet ID. The number that stand alone to the right side ends with S87.
Same symptoms continue.
Thanks,
Randy
door Randy
Apple iBook G4/1.2 12-Inch (Late 2004 - Op) Specs
Identifiers: iBook G4 - Late 2004 - M9623LL/A - PowerBook6,5 - A1054 - N/A
door mayer
