Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
Does the copper-tape surrounding the digitizer have to replaced.
I have disassembled my iPod for a front-panel replacement, and am unsure if the copper-tape surrounding the digitizer must be replaced.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
I don't think that it is strictly required when replacing the front panel - it might be there to eliminate RF interference around the digitizer connector. We have a 4th Generation Touch that we use for testing components that doesn't have the tape around the connector and it operates just fine.
Was dit antwoord nuttig?
Score 2
I accidentally ripped the copper tape connecting the center plate (which houses the home button) and the camera and now neither of my cameras work.../: help please
Yes because if you don't replace the copper tape your wifi antennae will not work properly, thus you will have to sit next to your wifi router just to get 2 bars.
were can we purchace the copper tape???? does any copper tape work??
Tearing the copper tape will not effect wifi or the cameras it's purpose is for grounding..
Voeg je antwoord toe
Elijah Ellis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,055
