Ga door naar hoofdinhoud
Which Upper Case do I have?
Does anyone know how to identify the Upper Case for a MacBook Pro Aluminum 17"? There are four slightly different ones, one for each MBP model, each with a different Apple 922-0000 part number (as noted on the parts pages on the iFixIt site). I have one here, but don't see a 922-0000 part number anywhere. Can anyone help me identify which model it is?
TIA,
Andrew Main
Is dit een goede vraag?
Score -1
2 opmerkingen
Please give the last three letters of your serial number and we can direct you to the correct part. Thanks
door
Thanks, but not sure what you mean. I have the Upper Case part, and want to find out which MacBook Pro model it comes from. There is a part number on it: 620-3778-A FAPW5009010 70105N19F122. Can you match that to one of the 922-XXXX part numbers of the Upper Case parts for the four MBP models? I know it's not the A1261, and probably not the A1229.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
17" Macbook Pro Core 2 Duo (2.33 GHz) Top Case w/ Track Pad
http://www.welovemacs.com/9227950.html
Apple MacBook Pro "Core 2 Duo" 2.33 17" Specs
Identifiers: Late 2006 - MA611LL/A - MacBookPro2,1 - A1212 - N/A
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Many thanks.
door
Voeg je antwoord toe
HandyMac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,029
