Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
Vraag afgerond
No power on USB port.
Hi,
My macbook air (A1304) has no power on it's only USB port. But the rest of the port is fully functional, so if a device is powered externally, they work just fine (same for externally powered usb hub's).
I've done some digging into machine and here's what i got. Instead of standard 5V, the power line has only 1.25V (just as the signal line). The port hatch is in good shape and the plug and sockets connecting it to the logic board are clean and have been refitted. The connector tape running from logic board to the port seems ok (tested with multimeter for conductivity and short-circuit). Resetting PRAM and SMC did not help.
Question 1: Any suggestions?
Question 2: Any ideas where else the logic board provides 5V I could use to power the USB?
Thanks for for Your time!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The hatch is prone to failure. In my case it was the digital lines of the video port - analog VGA worked fine. I think you should try replacing the hatch.
Was dit antwoord nuttig?
1 Opmerking:
Hi Eugene,
Thanks for you for the answer.
It took me a while ;), but i replaced the hatch, yet still no joy. Video doesn't work either (but that might be to lack of power signal which might be also taken from USB). Any other ideas?
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,194
