Ga door naar hoofdinhoud
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
20 Vragen Bekijk alle
Glass removal and substitution
Hi everybody, My screen glass is damaged and I'd like to substitute it with a new one that i found for a very low Price. Can I remove only it for example heating the glass? Everything is working fine so i'd prefer to not disassemble the entre Phone
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The disassembly isn't simply heating the glass.
Then you have to spend hours trying to remove the existing glue.
Then you have to purchase loca glue and a UV light.
The amount of extra work and equipment you need to purchase will not be worth it.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
What does he need to do to fix it?
door
The whole assembly is around $23USD
https://www.ebay.com/itm/LCD-Display-Tou...
and a roll of adhesive is $3
https://www.ebay.com/itm/3M-3mm-LCD-Scre...
door
Voeg je antwoord toe
Alessandro Balduzzi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 64
