Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
How to remove earpiece
I've hunted around for this, but I haven't been able to find it.
I've repaired quite a few iphones so am not a novice. However I've yet to be able to work out how to unclip the actual earpiece from the mid frame.
I can remove the sensor flex assembly, but not the actual earpiece from underneath.
Thanks in advance
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
you have to remove it from the backside. remove the ribbon then you can remove the speaker. if not careful, you will damage it. a non issue if you are replacing it. i use a microscope to do it and keep it intact. use a small pick or pointy tool.
Was dit antwoord nuttig?
Voeg je antwoord toe
Chris Zammett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,440
