Ga door naar hoofdinhoud
An industrial gas-powered stove by Vulcan.
27 Vragen Bekijk alle
The commercial stove oven does not stay hot
The Vulcan Gas Stove at work does not stay hot. We are not sure what is causing the stove to not retain heat.
Is dit een goede vraag?
Score 1
3 opmerkingen
No answer? How about a more descriptive question?
door
Comes on for 12 minutes goes out pilot light and all
door
Manon First see it is using an igniter or a pilot light.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds like a gas pressure issue, make sure the gas lines are not bound or pinched.
The pilot light should not be off or too low, and should be carefully adjusted to have a low burn to ignite the main burners.
When the main burners are on and suddenly go out, it could be an indication of poor flow of either too much gas or too much air, because air is required for the flames to flaming. A quick through cleaning of the burners should do the trick.
Hope that helps
-SF
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Willymae Smith-McNeal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 146
