Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Touch screens stop working when screen is down?
Replaced the screen months ago. No issue. It got a little water damage, still continued to work. Now the touch stopped working. I opened the phone and tough started working somehow. But when I go to secure the screen (click it into place and put the screws in) the touch stops again. Very frustrating. Help?
Is dit een goede vraag?
2 opmerkingen
careful you might have touch disease! oh, i love apple lol.
door
Was touch disease a problem with the 5 series?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The water may have done more damage than you suspect; this is quite typical. Normally, a water damaged phone should be properly decontaminated otherwise you will have latent issues.
In your case, I would carefully inspect the Home Button, it's flex and the connectors to see if there is any corrosion that could be causing this issue.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for the advice!
door
Voeg je antwoord toe
Austin Harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 44
