Ga door naar hoofdinhoud
Apple AirPods zijn draadloze oortjes die in december 2016 zijn uitgebracht.
85 Vragen Bekijk alle
Help I washed my airpods in a washing machine
Guys my AirPods and airpods charging case I washed it in a washing machine bymistakely forgot I had it in my pocket help…the green led light is not illuminating it doesn't work help if any one has any solution about it plz do share
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
My suggestion would be to put them in a bag of rice overnight. The rice will help draw out the water. If this doesn't work then I'm afraid you will need to buy a new pair since the water has likely killed the electrical components. It might also be worth letting them stay in the bag of rice for a few days. Good luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
That is a myth. Rice is not a desiccant, and only blocks air flow. Keep them warm with a lamp and fan.
door
Voeg je antwoord toe
Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 26
Altijd: 26,337
