Ga door naar hoofdinhoud
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
55 Vragen Bekijk alle
How to fixing water damage due to broken back cover?
I jumped in the shower today got my phone wet, i thought this would be ok since it has water resistance. I cracked my phone not too long a go and realized too late that maybe the water could get through the glass. sure enough my phone now cant charge and will turn on and off . Would changing the charging port and possibly the battery save my phone ? and if so where would i go about buying these new parts?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
As far as a source for parts, if IFIXIT doesn't have them then a simple Google search should get you some info. Just make sure the source offers guarantees on their products. If you disassemble your device, be sure to look for signs of corrosion around any connections/chips/ etc. If you find any, I would recommend cleaning the logic board (or having a repair business do it) in an ultrasonic cleaner with electrical component cleaner ( like Branson EC) . This will ensure that there isn't corrosion or oxidation anywhere that will cause further problems after you install a new battery. Good luck!
Was dit antwoord nuttig?
Here is the LG V6 Owners Manual - hope it helps :)
Voeg je antwoord toe
claudio flores zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 263
