Ga door naar hoofdinhoud
Has anyone managed to open their device yet?
I've toyed around with it a bit, and managed to unclip a couple of the clips on the sides in between the plastic and the fabric area, but don't want to apply too much pressure, due to the risk of things breaking, and the one or two clips that come un-done aren't enough to allow the unit to open. Has anyone managed to successfully open their unit yet?
Is dit een goede vraag?
Score 3
2 opmerkingen
Need to peel off the 'orange' rubber bottom. There are 4 torcs screws under there. Will need to apply a lot of heat to soften the adhesive
door
You can also just brute force rip the rubber off, or cut 4 holes to access the screws if you can find them. With the 4 hole technique, you can access the innards at will.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The solution is here: Just get the bottom of the device *REALLY* hot.
Was dit antwoord nuttig?
Score 2
https://www.allaboutcircuits.com/news/te...
For your reference.
Voeg je antwoord toe
r3pwn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,140
