Control doesn't turn on
The control does not react, doesn't work with the cable connected to the console
Is dit een goede vraag?
Your cable may not be working properly, in which case, you should check to see if it has any physical damage. You may have to buy a new cable.
However, this could also be a battery issue. You may have to replace the battery. iFixit has a device guide that will instruct you on how to do so.
Another issue could be that your controller isn't charging properly. As I mentioned earlier, this could be an issue with the cable. However, it could also be an issue with the charging port. iFixit also has a device guide that will instruct you on how to replace your controller's charging port.
Was dit antwoord nuttig?
my controller is on and virating not letting me do anything
I had a similar problem, my DS4 wasn't turning on, even though it was charging normally.
when I opened it I found that the (I think it is called) Ribbon Circuit Board ( a thin layer with many connection lines ) was broken on the like that connects the PS button, I order a new one online and replaced it and it worked perfectly.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,599
