Ga door naar hoofdinhoud
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
How much is it to fixed my screen
My screen is shattered how much would it cost to get it fixed
Is dit een goede vraag?
Score 16
14 opmerkingen
How much is it to get my screen fixed on my zte max pro
door
My phone screen the glass part is shattered from the top left corner. How much would it cost to fix the screen?
door
How much is it to fix my screen zte max pro
door
how must do it cast to get my phone screen fix
door
How my will my zte phonecist to fix the screen
door
9 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If you wanted to repair the phone your self, the display assembly is around $30-35 USD.
It would likely be $20-$40 labor for a shop to do it.
https://www.ebay.com/sch/i.html?_from=R4...
Was dit antwoord nuttig?
Score 9
4 opmerkingen:
My phone cracked up
door
It's easy to change the screen. Buy the screen and I'll change the screen for u for free.
door
Can you walk someone thru the repair via webchat?
door
How much is zte phone screen model Z982
door
Buy oem screen on eBay 28 bux, prolly 20 labor from "pro..." Or YouTube that ish yourself.
Score 3
1 Opmerking:
My phone drop in to water and the screen blank out
door
They are many places where you can get a display dependent on your location. See the guide below.
ZTE ZMax Pro Display Assembly Replacement
Score 3
Voeg je antwoord toe
Azea Brown zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 15,434
