Xiaomi Mi Mix wont power on
My Xiaomi Mi Mix showed low battery sign so I plugged it in to charge. The phone immediately went off. I pressed the power button to restart it, it showed the Xiaomi logo then immediately went off and since then (this was 2 days ago) it has not powered on.
Kindly note the following:
1. It didnt have water spilled on it
2. It didnt fall or have any mechanical damage
The only thing was, the battery was low, I plugged it in to charge and it went off and never came on again. I have used the same charger to charge other phones so I doubt if the charger is the source of the problem.
Kindly help, what is wrong with the phone?
thanks
Is dit een goede vraag?
11 opmerkingen
Please help me. Still stuck on this issue
door pystar
I was told on xda that it could be the charger fried some circuits or so. How can I verify if this is true and convert the phone to a paper weight?
door pystar
Please help. Still on this issue
door pystar
Hi @pystar ,
How long have you left the charger connected?
If only for a short while, give it up to at least 4 hours and see if charging has recommenced. Sometimes it takes a little while for the battery to recommence charging especially from a very low charge state.
If the phone does start to recharge allow it to fully charge before attempting to turn on the phone.
door jayeff
@jayeff the only fear I have is that maybe the former charger I used spoilt something inside the phone. I pray and hope not because I dont know why something in the phone could fry just by plugging in a charger I have been using for a while now.
How would I know if that is the case?
door pystar
6 commentaren meer tonen
