Ga door naar hoofdinhoud
De B6- en B7-versies van de Volkswagen Passat zijn grote gezinsauto's met voorin geplaatste motor, geproduceerd door de Duitse autofabrikant Volkswagen. De B6-lijn van de Passat werd geproduceerd tussen 2005 en 2010, en de B7-lijn werd geproduceerd tussen 2010 en 2015 als een facelift van de B6-lijn.
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Is dit een goede vraag?
Score 3
3 opmerkingen
this worked for me omg thank you so much
door
Glad it worked, pass it along...
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Push on brake and hit button forgear shifter a couple of times.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
door
It worked for me. Thank you!!
door
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
2 opmerkingen:
I was programming my remote key fob now the fob is stuck in the ignition
door
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
door
Is there a battery in the fob?
If the five won’t come out of the ignition?
Voeg je antwoord toe
Darby Rosello zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 32
Altijd: 22,440
