Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Vragen Bekijk alle
Repaired ylod, lost it's backwards compatibility
I repaired a backwards compatible ps3 after it got the ylod using the ifixit kit, and it works fine now, except that it no longer has the ability to play ps2 games. This feature was the only reason it was repaired, is there a reason this feature would be lost, and is there a way to restore it?
Is dit een goede vraag?
9 opmerkingen
Hi @snafumonkey79, can you try playing any DVD Video disk?
door
Yeah, that's definitely the first thing I'd try in this situation.
door
Is this a slim, super slim, or fat model? If it's not too much trouble, what is the model number?
door
@pccheese The only PS2 backwards-compatible PS3 is the FAT, to be more specific, the FAT with 4 USB ports and memory-card readers.
door
@alexniculescu I know that. That's why I was asking. But strange thing can happen, so it doesn't hurt to ask.
door
4 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@snafumonkey79 just in case it doesn't work, here's a potential work-around: http://www.ps3hax.net/showthread.php?t=3...
Edit: the backwards compatibility happens because of the emotion engine chip, according to this: http://www.neoseeker.com/forums/30444/t1.... I'd make sure that's connected correctly, etc.
Check out Step 35 of the teardown for a look at where it is: PlayStation 3 Teardown.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
@kaykay I did not notify you about Rachel blowing right past 500 points because she still had an iFixit avatar up. It now appears she wants that tee shirt since she's just a peon now ;-)
door
Voeg je antwoord toe
Jason Lawrence zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 662
