Ga door naar hoofdinhoud
Repair guides and support for the fifth-generation Century, a series of front-wheel drive coupes and sedans manufactured by Buick.
15 Vragen Bekijk alle
How to replace interior and exterior door handle
I'm needing to replace everything for my door handles, including the door handles themselves and the mechanism inside the door. Can someone post a how-to please? I've looked everywhere on YouTube and Google videos, still can't find a repair/replace for this specific issue. Also please include all parts I'll need to buy to get the job done. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The outside door handles are reached by removing the inside door panels and then unbolting two nuts, (usually 10mm.) The handle usually has a push rod which engages the latch mechanism . I can't tel from the question what the original problem was.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
First take the door panel off so you can access the handle. Here's how: https://www.youtube.com/watch?v=yPJegT_I...
Go here and enter your exact model for the parts: http://www.autozone.com/collision-body-p...
Score 3
Voeg je antwoord toe
James Christensen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 44
Altijd: 2,047
